2G What is this noise!
tylersmith2014
47
Jul 1, 2012
Arlington, Texas
My car is a 97 eclipse gst automatic. Everything is pretty much stock. Just replaced turbo a few days ago. Car is running like shit and is making this noise that sounds like drumming/ticking/clicking etc.... Car has a huge loss of power and if i try to drive it, the car just dies on me. It does NOT smoke or anything.if you have any idea what this may be please let me know asap. Thanks
no the noise started when the turbo went out. Thats why I thought it was just the turbo.
Just some fyi about the turbo.
The old one made the car smoke a ton and had a ton of shaft play and wasnt rebuildable. So i replaced it with another t25 with zero shaft play.
Sounds like either a major exhaust leak, or the turbo shaft isn't spinning. Does the turbo spin freely? Did you torque the manifold and down pipe to spec?
That's not good! It could definitely be a spun bearing. If you are hearing the sound up top on the intake side, take the valve cover off and take a look, if you don't see anything obvious it's time to pull the motor.
