What is this connecter go to?
4g63and420a
140
Mar 22, 2008
white plains, Maryland
Ive been over snowboarders tech article two dozen times and i cant find this. Its a black wire with a small green line on one side. The connector is plugged in but there is now wire out of it. The car is a 95 talon tsi
It is used to ground timing when setting your timing. Is it still connected to the car? I just tucked mine out of the way.
If you get dsmlink you don't really need this connector any more as you can ground timing through dsmlink.
Here’s the post in snowborder’s tech article describing that connector.
