what is the wideband controllers purpose?
speedy_talon28
364
3
Apr 1, 2006
elkhart, Indiana
this might be a dumb question but, I'm just curious about this. what is the wideband controllers purpose, and can a wideband sensor harness be hooked directly to a air/fuel gauge without a controller? wideband is new to me.
http://dsmtuners.com/forums/showthread.php?t=247118&highlight=wideband+controller
That should cover what you're asking, I think. It's more of a monitoring system then a controller. I'm not really familiar with it being called a "controller" though so I may be wrong. I've got the NGK AFX wideband.
thanks for that info but, it doesn't anwser my question I want to know if I could use just the sensor and gauge
<a href="http://imajr.com/Altar1_130624" title="Click for full size image." target=_blank><img src="http://imajr.com/th/Altar1_130624.jpg" border="0"></a> <a href="http://imajr.com/Altar1_130627" title="Click for full size image." target=_blank><img src="http://imajr.com/th/Altar1_130627.jpg" border="0"></a>
here's a wideband sensor, the harness pluged into the sensor is a built-in controller so, they say andyou still need a gauge
<a href="http://imajr.com/Altar1_130644" title="Click for full size image." target=_blank><img src="http://imajr.com/th/Altar1_130644.jpg" border="0"></
You can, but you will probably kill yourself trying to look at the tach and the WBO2 at the same time when you are trying to tune. I went with the AEM UEGO and plan on wiring that into the ECU so I can log the voltage on my PocketLogger.
