What is the turbo o exhaust manifold gasket called?
The one you want or the best one is the 7cm Turbine Housing Gasket from RoadraceE , thats the one i went with, its alot better than the copper ones alot of places sell the price is $20 but its will worth it.
Here is a link also for ya -->RoadRaceEngineering
If you are going to advance you want to ask for the turbo mounting gasket set. It will come with that gasket. It is the good one too not the copper one.
so what is it called? i bought a composite one from autozone about 2 years ago. i need a replacement because my metal gasket cracked. do they make composite sheets for you to cut out yourself? my old oem exhaust manifold was ported along with my 16g hotside but recently i discovered a crack in my manifold. so i replaced it with another oem manifold and now i need to match it up with my turbo hotside port hole. but since we did a custom diameter i need to do it myself again and i cant find the appropriate size. anywho whats the gasket from the turbo hotside to the exhaust manifold called?
The 7cm gasket is for any DSM-flanged turbine housing with a 60mm inlet; the 6cm gasket is for 54mm turbine inlets.
ok i understand now.
The one that was originally on my setup was made of aluminum.
is that weird?
i wanted to make another one out of aluminum and coat it with copper spray.
what do you think of that idea?
