[RESOLVED] what is this gasket called?
9920gGST
Aug 27, 2006
Hayden, Alabama
when taking apart the bottom end, after you take the timing belt off there is like a aluminum piece that goes on the front of the block that has to come off to get the crankshaft out. I cant find anywhere that names what its called and I need a new gasket for it
Depending on mileage you may want to replace the front case as well . However it is expensive but vital to the car .
would somewhere like advanced auto be able to order this or do i have to go thru a stealership or is there a online site?
I posted a link to extemepsi.com's 7-bolt front case gasket in my first post, just click the blue letters that say "front case", but if you need a whole new front case try this link.
The front case houses the oil pump. Like Ben said, it's an expensive but vital part. I'd replace it to be safe. While you're at it you might want to consider a Balance Shaft Elimination kit, good peace of mind and will only cost you about $42, check the vfaq.com writeup for pics and instructions on the BSE kit. Don't buy from a dealership, you'll pay much more for the same thing if you do. Extremepsi doesn't sell the parts as a kit, or if they do I can't seem to find it, if you wanted to make it one stop shopping you'd have to piece together the parts separately from them.
extreme has them and so does every mitsu dealer.
Mentor Mitsubishi in Ohio prices
MD185528 Oil filter housing gasket (smaller one) $1.52
1064A040 Oil Pump/Front case gasket $8.81
MD327450 2g Oil pump (95-99) $175.48
