what is the exact location of the power feed
bmoha2
1,046
Mar 3, 2007
madison, Wisconsin
12v power source for the fuel pump in the underhood fusebox? I want to replace only the single wire that feeds the fuel. I need to know exactly where it is in the main stock underhood fusebox on a 2G and which wire I need to cutout and replace on the stock fuel pump wiring connector at the fuel pump. The problem is the gauge of the wire. I want to replace that single wire with a 8ga wire. I don't want to add any more complexity to it than it needs. Simple as possible. I will also run a new shorter 8ga ground wire to a location close to the fuel pump.
    • frosh29
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
