90 GSX
- 322
- 2
- Jun 24, 2004
Fremont,
California
I have had nothing but problems since installing my ACT2600 a couple years ago. My car has always engaged near the floor but it was never a problem. After I put the ACT in, it was okay for a while, but it slowly got to a point where I could feel the clutch was dragging when I went into gear. Then eventually I couldn't shift.
I replaced the slave cylinder, brought out the master rod adjustment all the way, I got the pedal assembly welded. It was fine for a while then I started experiencing the same symptoms as before and eventually I couldn't shift.
Then I pulled the trans and put a couple washers under the pivot ball. It was fine for a while then it deteriorated again. I went under the car and the fork was broken into two pieces.
I then bought a new ball and fork from shep and put them in and it shifted great for about 1-2 months and now I'm back to the same position. I estimate in about 1 week if I keep driving it will become undriveable.
I can pull the trans and put the washers back under the pivot ball but it's just a bandaid again. How can I permanently fix this bloody clutch without going to a stocker? I even have the stupid braided line from the bracket on the tranny to the bracket on passenger side of the engine bay. Should i buy this techna-fit deal??? EXTREME PSI : Your #1 Source for In Stock Performance Parts - Techna-Fit Clutch Line : Mitsubishi Eclipse 90-94
