what is my baby worth in the real world
96accordsir
36
Apr 4, 2011
Phoenix, Arizona
I've been thinking of selling my car but I'm sure what I value it at(since I built it and have had it for a while) is different then it's real world value. I may just end up keeping it forever LOL.
Anyways it's a 1998 Gst spyder with just under 100,000 on the chassis and under 5,000 on the longblock and most aftermarket parts.
Here is the mod list
Engine:
-original 7 bolt motor#
-S.I.M. cylinder head (stock rebuild w/ 3g lifters)#
-Manley 8.5:1 pistons
-Manley h beam rods
-all new acl bearings
-ARP headstuds#
-ALL new gaskets
-new oem waterpump
-new oem oilpump#
Bolt ons and turbo kit:
-XSturbo manifold w/ flange for external wg
-turbonetics t3/t04e ball bearing 50 trim stage 3 .63 ar#
-tial 38mm wastegate
-Greddy RS blowoff valve#
-Greddy 24v fmic#
-custom built 3" downpipe and dumptube
-custom 4" aluminum intake w/ k&n
-apexi n1 dp back exhaust#
Electronics and fuel:
-AEM series 2 ems#
-spark tech coil on plug ignition setup
-AEM UEGO wideband and digital gauge#
-gm iat sensor
-gm map sensor
-walbro 255 lph fuel pump
-pte 880cc injectors
The rest:
-Competition clutch stage 5 clutch kit
-18x8 mb wheels
-good 245/45 tires
-dropzone struts
-eibach pro kit springs#
And some pics to give you guys a better idea.
Thanks in advance for the help you guys.
Similar 2gs in my area go for around 6k, the spyder model typically brings in around 800-1000 more. It all depends on what someone will pay for it really, if it were me I'd put it up for 7 and see what happens.
Anywhere from 6 to 9k. You have it modded, but in your case i dont see that being a detractor of value. The EMS2 is a bonus to a lot of potential buyers as well.
Id say list for 8500 and go down to 7500 if you have to
You are in Phoenix, did you retain the AC? IF so, the above suggestions are valid. If you removed it, then you will have to knock a grand or so at least.
^^^QWhat he said. I based what my estimate off it being modded, but not "race car modded". Meaning you still have working ac/power steering etc and all the buttons/gadgets work like factory.
Edit: I want to kick myself for painting my car silver/gunmetal. I had that deep maroon color like OPs. Man, that is one good lookin car.
