What Intake Do You Suggest?
defury
129
Jul 4, 2010
Regina, SK, Canada
Going to buy one, what do you gys think I should go with. Links to the best deal if possible otherwise just the name works.
JMF is JM Fabrications & yes that would be intake mani, not intake. Check out the buyers guide on this site or search intake, lots of info already on here to help you make your choice.
Personally I'd recommend FP (forced performance), it's a 4" intake so can be adapted to work with the smaller turbo's but is still usable if you want to go with a larger turbo in the future, that has a 4" intake, etc.
Do you happen to have a pic of the fitment? How well does it bolt to stock MAS, and stock turbo from the get go?
Is something like
http://www.extremepsi.com/store/customer/product.php?productid=16345&cat=476&page=1
Any good comparitively? looks almost identical to an ebay kit for 1/3rd the price but ebay is kinda eh for quality.
*edit* yea it looks like it doesn't bolt to the MAS at all instead assumes you are using a GM MAS.
ebay intakes have horrible fitment issues you will have to wedge the filter in LOL besides that they are pretty good but heat soak very very fast
From the sounds of it that doesn't bolt to the stock MAF. I noticed your is though, what filter are you using. how is the fit?
Yes, the FP intake will bolt directly to a stock MAF. Just need a reducer at the turbo inlet if your running a stock or other smaller turbo like the 16g series, etc. My galley has pics with a stock MAF. Fitment is perfect, has same basic dimensions as a stocker, so put the MAF in the same general area. Injen & I would assume the other knock off out there, will push the MAF closer to the passenger fender.
I also would never run one of those knock off filters. I can't say for sure about their quality of filtering but I have seen them come apart. Not so bad if you have a MAF inline but still have the potential to suck something through the turbo.
With the FP, there's no additional ports for vacuum lines, so you just drill, tap & install any required barbed fittings. Stocker will have 3 but most guys no longer need 3 after different mods.
FP intake, Maf Adapter & a K&N or AEM filter would be my first choice.
Yea, going to go that way. Which filter did you grab? Also what coupler will I need to bolt up to the stock t-25
Forced Performance Turbochargers: K&N Cone Filter
I am assuming I need 9'' with 4'' inlet
and
Forced Performance Turbochargers: FP DSM Aluminum Intake pipe
With BOV flange = yes
and
4''-4'' and 4''-2.25''
Or will I need smaller for the t-25
Comes out to to $209 USD before shipping /cry
and
and
For the T25, the inlet may be even smaller, but if I remember correctly there's a rubber spacer on the stock intake that you can remove to install on the T25 so the 2.25" adapter should work regardless.
For the filter, the 9" length probably won't work with a stock MAF. Normally you want something like 5.5-6" length & the base dimension is actually 4.5".
An example of a MAF adapter & filter:
https://www.rtmracing.com/xcart/product.php?productid=16740&cat=764&page=1
https://www.rtmracing.com/xcart/product.php?productid=16741&cat=764&page=1
Those are links from a Canadian store, they also sell the FP intake & couplers. So it may be a cheeper route, if FP only ships via UPS as the brokerage charges for someone without a shipping account are stupied high.
If you are keeping the stock MAF and are not planning on going speed density or a GM MAF in blow through then the FP intake is a solid buy and worth it even for upgraded turbos or stock.
If you are having plans of going MAF less then hold off until you have your other parts and get the proper sized Dejon Tool intake. Their 4" intake is a very nice piece but I wouldn't only get it for MAF less applications.
Get the ebay one
That was one of my very very first mods and had no complaints about it. A pipe is a pipe... there no voodo magic from a $25 intake to a $150 intake pipe... well maybe just the filter (K&N)
EDIT:
Here's a good read about ebay intakes
http://www.dsmtuners.com/forums/art...-style-intake-pipe-filter-review-install.html
I second that, why spend $150 when you can buy the same thing for way cheaper, most ebay kits even come with the mounting plate for a cone filter too. I would buy it for my 1G but I'm dumb and I don't wanna recirc my bov so i have to buy one from dejon powerhouse which is also a good brand. I have Dejon hard piping and sidemount intercooler since i'm oldschool like that, its not cheap but damn is it worth it.
I have no current plans to run a GM MAS. I think I am going to go with the FP for now with a 6'' K&N and the adapter in the previous link.
I just need to figure out how to tap my valve cover breather hose into it.
You could also just put a filter on the nipple coming off of the valve cover, thus eliminating the need for the hose. Check out the picture dsmdeliveryboy posted.
Ive read that that's not the most efficient way to, or even correct, way to utilize the breather system.
