Resolved What injectors are these?
jakk220
1,320
320
Nov 13, 2010
Akron, Ohio
I am going to throw these injectors in my 1G that I had lying around. I was told when I got them that they were PTE 880cc injectors. When I ordered the PTE seals for them and they did not fit, it made me question what injectors they were.
So I called PTE and FIC to see if it matched any of there part numbers, and both of them said they were not their injectors. But FIC did say that their seal kit would fit it.
Does anyone have any idea what injectors these might be? The number that is cut off is a "5"
What number is printed (not engraved) on the top of the black part?
I will have to check when I get home and update you on that. I didn't recall seeing any other numbers though.
If they are 880/850 injectors they’ll have 17113743 printed on the top. Fic and Pte both use the same Rochester Delphi injector.
Good to know. I will definitely check for that. Its weird that they would not have asked for that part number instead.
4215 17113743. That's what is printed on one of them
Fic and pte 850’s are exactly the same part. They’re all Rochester Delphi 85lb injectors. They are matched in batches and resold as either fic or pte injectors. Several other companies sell these too.
Interesting... The more you know. Hopefully they serve me good. Thanks again.
