What in the "blank"........
slowboy101
285
Nov 26, 2009
Lakeville, Minnesota
Ok so here's the deal, I finally got the DSM done after a year of work and now the only thing holding me back is that there is a leak where the fuel return line connects to the fuel pressure reg. excuse my language but FML!!!!!!!
And?
Fix the leak since you aren't done with your build until it's running properly.
It ended up being the guage on the regulator I didnt tighten it down:ohdamn: but now I have coolent leaking somewhere on the lower coolent return pipe behinde the turbo. :banghead:
These happen during builds. You only have a water pipe and the coolant lines from the turbo back there. Not hard to figure out.
If you reused the copper washers, then that's your problem.
I believe its the little neck that hangs down the the old coolent line connected to from the factory at lease I hope it is
You live less than an hour away from my house LOL. I would help if I was around.
then come around LOL I live right off of 35 right where 35w and 35E meets basically right accross the highway from buckhill
