what horse power range
Status
Not open for further replies.
shawnmr
59
Aug 10, 2008
fairmont, West Virginia
what horsepower range do you think i am at....there is no dyno close to me
bored 40 over with, with wis pistons all apr bolts, balance shaft eliminator kit, acl 25 over rod bearings 8.3:1 compression, head is rebuilt to stock stock injectors and 14b turbo
hard UICP , Turbo XS Type RFL,3 inch bullseye intake w/k&n air filter,ported 2g manifold,autometer boost gauge,autometer air/fuel gauge ,255 lph fuel pump,aftermarket fuel pump regulator. eprom computer, 3inch gm maf w, 2.01 translater, custom 2 1/2 inch down pipe into aftermarket 3 inch cat and 3 inch Apex'i N1 Exhaust
thanks for your help
You should be able to get between 250-300@ wheels on pump gas depending on your boost level.
1,236.95555555 h.p at the front left wheel
Around 300, depending on tune.
BTW, bench racing is against the rules.
Status
