Resolved What fluid to use in manual trans with Quaife lsd?
Brad Bell
202
11
Aug 15, 2014
Levant, Maine
I've got a manual transmission for a 420a (NVT350) with a Quaife limited slip differential. What should I use in it? I know with a stock transmission you're supposed to use ATF+4, but with this lsd I'm not sure what to use.
Thanks.
I've got a manual transmission for a 420a (NVT350)........ I know with a stock transmission you're supposed to use ATF+4.......
Don't run ATF+4
Use this (part# 04874465)
or Amsoil Synchromesh full synthetic 5w-30 MTF
https://forums.neons.org/viewtopic.php?t=323499
You can also run Mobile 1 5w-30 High mileage oil. This info came from Ed Peters himself. I use to run Amsoil, but Mobile 1 is just easier to get.
