eldiabloz13
- 612
- 8
- Mar 2, 2005
Fairhaven,
Massachusetts
OK. So I know I've kind of fallen off the forum's, but Im back. If this is posted in the wrong area feel free to move this by any moderator. I have sent a engine out to a local shop to be completly built. A year and a half later the man still didnt even touch it. So here I am now. While the origional engine was at the shop it was there for so long my friend gave me another engine. Now that I have both back in my possession im stuck on which one to use.
Here are some pictures of both engines. I want to know if any head, block, or internals are better than one another,damaged, etc...I want to know which head would be best fit with which block to give me 450awh. As well as which set of rods to use again with which crank. If there are more details you will need to see to give proper info feel free to ask and I will get them.
These are the pictures of the first engine that was sent out but never worked on.
Head top...
http://i2.photobucket.com/albums/y19/eldiabloz13/DSC00375.jpg
Head valves....
http://i2.photobucket.com/albums/y19/eldiabloz13/DSC00364.jpg
Block oil side...
http://i2.photobucket.com/albums/y19/eldiabloz13/DSC00371.jpg
Block side...
http://i2.photobucket.com/albums/y19/eldiabloz13/DSC00372.jpg
Crank...
http://i2.photobucket.com/albums/y19/eldiabloz13/DSC00373.jpg
Crank mains.. Do those grooves mean this is damaged.!!??
http://i2.photobucket.com/albums/y19/eldiabloz13/DSC00362.jpg
Pistons and rods...
http://i2.photobucket.com/albums/y19/eldiabloz13/DSC00380.jpg
Piston tops...
http://i2.photobucket.com/albums/y19/eldiabloz13/DSC00378.jpg
Now here are the pictures of the engine my friend gave me. He claims it came from a 95 but i counted 6 bolts on the crank. Can anyone help me on what engine this may be as well as what rods and pistons these are.
Block bottom...
http://i2.photobucket.com/albums/y19/eldiabloz13/DSC00365.jpg
Block Top....
http://i2.photobucket.com/albums/y19/eldiabloz13/DSC00366.jpg
Block side...
http://i2.photobucket.com/albums/y19/eldiabloz13/DSC00367.jpg
Block oil side....
http://i2.photobucket.com/albums/y19/eldiabloz13/DSC00370.jpg
Head valves....
http://i2.photobucket.com/albums/y19/eldiabloz13/DSC00376.jpg
Head top...
http://i2.photobucket.com/albums/y19/eldiabloz13/DSC00377.jpg
Pistons...
http://i2.photobucket.com/albums/y19/eldiabloz13/DSC00381.jpg
Pistons and rods....
http://i2.photobucket.com/albums/y19/eldiabloz13/DSC00382.jpg
Now here are two pictures that make me wounder some things. The piston on the left(first pic) and on the top(2nd pic) came from the engine that was given to me. The other one in both pics are from my origional engine. Why does one set of pistons have a mitsubishi symbol on them but the other dosen't. Also the pistons that are cleaner came out of a engine with 186k miles which was my origional engine. They have no markings on them though.They also have a smaller wrist pin center hole. As well as the rods are darker and seem to be more dirty than the other. What is the deal with them. Are they both origional.Which ones will be better to use to build on.
http://i2.photobucket.com/albums/y19/eldiabloz13/DSC00383.jpg
http://i2.photobucket.com/albums/y19/eldiabloz13/DSC00385.jpg
Thank you for all the help in advance.
Head top...
Head valves....
Block oil side...
Block side...
Crank...
Pistons and rods...
Piston tops...
Block bottom...
Block Top....
Block side...
Block oil side....
Head valves....
Head top...
Pistons...
