what do i need to log?
boostedracing
Jan 9, 2010
Gaylord, Michigan
i have a 98 gsx that i just put a gm 3" maf and translator on. I know that the car is running super rich, and it keeps breaking up under mild to heavy accel. I have evoscan and am able to log, but i dont know exactly what i should be logging so that you guys can look at the logs and tell me exactly what needs to be done to the translator. i am sure i need my fuel trims, knock, and the afr map but after that not sure. any help would be greatly appreciated. thanks
i am able to flash my ecu, however i need to know what to even be looking for first, and with the translator, why would i not just make my changes on that rather then reflashing the ecu?
ECU Flash has soooooooooooooooooooooooooooooo many more functions than a translator. You can use EVOScan to log if you want to monitor everything. Read up on those links and it will explain it all. Then you will understand why.
