VPrime
- 802
- 3
- Feb 5, 2006
Lonon,
ON, Canada
okay, where to start....
I bought this manual boost controllor from ziggy (Busta boost controller), and i think from day one it never worked (defective mbc?) and i posted about it. I posted that originally it would give me unlimited boost, and the "knob" did nothing. well it turned out it was either the "knob" or a kink in one of the lines (i "fixed" both so i dont know which did it.)
And it sort of worked... It no longer gave an unlimited rating so i was happy. I assumed ti was a problem with my car and not the controller.
Any ways forward to a week ago... I thought i tried every thing to get the mbc to work.. but apparently i forgot to try switching the lines (i thought i did but my brother told me i didnt) so i tried. Well I got unlimited boost again witht he knob all the way out... then it blew one of my pipes off... put every thing back to gethor, and noticed that it would no longer boost an unlimited amount.
It now goes to like 12-14 psi and then it no longer boosts and the gauge drops to like 10ish and I can no longer hear the turbo "sucking" all i hear is a WOOOOOOOOOOOOOOOOOOSH....... (this is after it build the 12-14 psi).. then the car sort of kicks/lurches and it stays at 10... and if i try and build more boost, it does the same thing.
STILL with the controller in backwards (according to the instructions) I tried turning the knob, when i turn the knob so it goes in, i can only make 10-11.. so i guess it sort of works, but back wards...
I now have the boost controller disconnected and now justr unned the OEM boost controll solenoid, and it is fine. (11-12 psi)
Any ways just wondering
1)What could that wooshing noise be?
2)Why can I no longer build unlimited boost (i know its bad any ways... but isnt it worse that it can no longer do it?)
3)could my turbo now be toast? I dont get any smoke or any thing.
ps. i forgot, when i run a line straight from my turbo to wastegate i only get 10 or so PSI.
AND I DO have an aftermarket gauge.
