What color krylon is closest to stock?
jakelandry
985
169
Oct 13, 2009
Minden, Louisiana
Im painting my interior in an attempt to turn it all black. I will probably sand it all down and prime it then throw some krylon fusion over that unless anyone has a more sufficient way which will last longer or a better paint. Would gloss black or satin/flat black be closest to my stock black dash?
Do not use Krylon. Go to your local paint store, and pick up what is called "SEM Landau Black". It is the closest match to an oem finish, and holds up far better than any other walmart paint can I've used. It will be a little more expensive, but is well worth it.
Feel like it would be reliable enough to do 90% of my interior plastics with such as front and rear panels, lower half of dash, etc...?
before i answer... :heystupid: DON'T USE KRYLON FUSION! damnit. there is INTERIOR specific rattle can paint they sell at autozone that ive seen people use. buy the paint (if you must paint your interior) then follow the directions on the can...
:dsm:
