What clutch/flywheel do I have?
NOSLO2PT0
2,686
250
Aug 31, 2002
Joliet, Illinois
I'll try to get pics but I couldn't take any today. I pulled the trans off my Laser and found an aftermarket clutch/flywheel. Unfortunately, I have NO idea of what they are. The pressure plate is blue, has NO markings whatsoever. Very light pedal feel. Clutch disc is a clutchnet 6 puck sprung unit.
The flywheel appears to be a Fidanza. Has the removable friction surface insert. Rear of the flywheel is a machined silver color. There are some engravings on the flywheel that read:
F012226
MIT4-6991
Anybody know what these mean, or what clutch/flywheel I have?
I've used a couple before and they hold up really well.First one I did 100's of launches and Hard driving never slipped unless I made it, probably somewhere around 15k on it too...From the sounds of it I had a stronger PP though,
I bought one for a cheap replacement the first time after, I had a spring pop out of a ACT disc.
The Design was at the time Way better then. There was actually something holding the springs in...
I'm pretty sure ACT has long since redesigned them but still.
I personally wouldn't use that 6 puck with that flywheel though I've always used them with a ACT street lite
