What arps are these?
Sepison
75
Jun 4, 2013
Orlando, Florida
Ok, so I have searched on google and the forums and I am
Still confused.
So I have these arp studs that are 11mm thick for my 7bolt, but the nut is a 14mm.
The stud also has the name arp at the top as well as an Allen wrench socket. Are these regular arps? They can't be 6bolt studs because they measure the same width as the other set of Arps that I bought from arp directly for a 7bolt.
Differences
- 14mm nut
- Allen wrench socket at the top
thanks for the help
The newer ARP have the hex bit at the top to help ease install and removal of the stud.
The 14mm nut is a bit of a throw tho.
Still a 12pt?
Still a 12pt?
Yess still a 12pnt, I found these in glove compartment of a gsx at the junkyard, they are torqued in my engine I'm about to drop. Could they be 6bolt nuts on 7bolt studs?
If that was the case, the nuts would not have taken the torque..
I wonder if a replacement nut set from ARP.. To have a larger clamp area under the nut.
