what are these plastic splash guards for
PlanZero
1,516
267
Aug 13, 2013
Easton, Pennsylvania
Okay I'm not sure what they're called. They attach to the front wheel well splash guards and curl around to the undercarriage. They have holes as if they bolted into something, but I don't know what since they just hang down underneath. Now that my car is lowered they're a nuisance ### they're only two inches from the ground. Can I remove these without exposing too much, or better yet what do they attach to? I cant find the holes! (Haha)
No, these are attached to the inner wheel well splash guards, inside the wheel well behind the knuckle, and go down underneath. They curve down and and look like they're supposed to attach underneath. Mine are just hanging there, and the one on the driver's side is almost touching the ground. As I'm looking at the Hayne's manual diagram of the underside they look like they're attached to the undercarriage on both sides. Mine are so warped I don't think I can push them back into place, and the one on the passenger side is almost touching the ac pulley already. can I just remove these, or should I hunt for replacements at the junkyard?
