What are the power capabilities of this turbo?
N1te
70
Nov 7, 2005
Arlington, Virginia
What are the power capabilities of a T3 turbo with an A/R of .70, a .62 compressor wheel and a .50 exhaust wheel?
If you know the mass airflow rating of the turbo (in lbs/min), then you can approximate the horsepower (at the crank) using the following formula:
HPcrank = mass airflow (lbs/min) * 10
Please note that this is only a rough approximation - your results will vary depending on your tune.
I don't know what the cfm rating of it is... Wish I did. Here's pics:
Pop the compressor off and get the inducer/exducer measurements. Any other numbers? How about turbine specs?
I agree, that mani looks like a sick little monkey.
It is a T3/T4 alegedly. No serial numbers what so ever on it though. After looking at other turbo flow charts and specs I think it may be a T3 60-1
The only way to know is to remove the compressor housing, then measure the inducer and exducer of the compressor wheel. If you don't do that ,you're just going to get 15 more guesses and no facts.
