Were to buy a 2g Crankshaft Key way !
v8killer
371
5
Oct 4, 2002
harlan, Kentucky
i got a remain crank from advance auto and i left my keyway in my old crank ! does anybody know where to find one !
Last time I checked Slowboy had them listed on their site. They usually list the part # as well (if you don't have CAPS), so you could just pick one up from your local Mitsu. More then likely JNZ Tuning would carry them as well.
The keyway is the space machined into the crank. Most shops should have a replacement Woodruff key.
It's a little unsettling one wasn't included with the crank, but that's the way things are getting out there.
While I would agree that a purchased crankshaft sould come with a woodruff key, I have yet in twenty plus years to have one come with a new or remanufactured crank. With that being said the reman shops out there must have a pile of them, but most likely for a small fee.
i ended up getting one out of an old for ford 302 crank i had laying around, it was the sam width but i had to cut it down to fit, i have had trouble in the past with 6 bolt crank bolts backing out the the crank sprocket hub would try to strip but the woodruff would be fine so i hope i don't have any problems with this 7 bolt !
