Weird tranny issue......
gsxrtalon
395
Apr 23, 2005
Harrison, Michigan
Heres the problem guys, about a month ago I replaced my master cylinder and got everything working right again. Well since then every morning for the last couple weeks I will go out to start my car in the mornings and put it in reverse to leave and it just doesnt want to go into gear. This is the same not only with reverse but basically all gears, they go into gear but very hard. I think I might have a tranny leak somewhere, do you guys think this is my problem or is there another culprit. The more I get on it and try to shift the harder it is to get into gear. It seems the more I drive it and warm it up the easier it gets........weird. Thanks guys
Search and you'll get a lot of results. The only thing you can do is to go out and look.
Do you have trouble going into gear with the car off?
Do you notice any leaking? Have you checked the slave cylinder?
