Weird sound
RonRonTSI
288
Jan 25, 2007
Lusby, Maryland
i cant view the vids since im at work LOL but a raspy grinding could be play in the turbo.. pull off your intake and check for shaft play
edit: i missed the "so loud and makes the car vibrate" part. shaft play wouldent do that LOL...
no its not the turbo
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf?file=http://vid324.photobucket.com/albums/k339/RonRonVc07/VE_1022091705.flv">
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf?file=http://vid324.photobucket.com/albums/k339/RonRonVc07/VE_1022091704.flv">
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf?file=http://vid324.photobucket.com/albums/k339/RonRonVc07/VE_1022091702.flv">
failing/loose pulley such as tensioner and idler. debris hitting the crankpulley(harmonic balancer) could be the balalce shafts. but it sounds as if some think is in your exhaust. I'd do a compression test after a good eye survey... what have you checked already?
I'm unfortunately not somewhere where I can listen to or watch those vids, but do you happen to run a heat barrier gasket on the intake side? If you don't have your EGR port blocked off in the exhaust runners hot gasses from anti-lag can go into the EGR system and melt those gaskets, causing an exhaust leak in your engine bay. Just a thought.
