Weird problem, dont know whats the problem
H.A.R.T 4G63DSM
84
Dec 19, 2003
Las Vegas, Nevada
Okay I had a problem with my old tranny, I swapped it in for a jdm tranny with 30k miles. When I was doing the swap I also changed the clutch to a replacement exedy clutch. I dont know what I did wrong but it wont go into gear at all. When I turn the car off and put it into 1st, it starts to move, and sometimes I cant even pull it out of 1st. I dont know what this problem sounds like but please any help me. I also did a tranny flush.
If you didn't adjust your clutch hydraulics, it can cause problems such as you are describing. I believe www.vfaq.com has an article on how to adjust them under the drivetrain section. Also, check out www.taboospeedshop.com for more information.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
