scott90gsx420
- 603
- 5
- Sep 25, 2010
nampa,
Idaho
Ok so i have had what seems like a misfire for a while. Issue started months back and hasn't got worse but hasn't got better. The car will misfire/pop especially at idle. When it does this the W/B goes a bit lean then is good again until it misfires again.
There is no CEL and I noticed it doing this right after me and my brother were out tuning the car a few months back. It was running fine we did some tuning and when i got back there were two issues one being this misfire and the other being that my alternator was wobbling around inside the casing (Like you could see stuff inside it wobbling back and forth.) I replaced the ALT but the misfire issue is still there.
The issue happens mostly when idling but does happen when cruising at low RPM's and when decelerating. In boost its just fine and the car doesn't seem to do it while cruising (Unless below like 1500rpms).
It DOES NOT do it during initial warm up but after the cars warmed up a bit it starts doing it.
It also DOESN"T always do it. For example I'll come to a stop and it will idle fine for 10 seconds or so then it will start popping.
And it isn't consistent so it will pop/misfire then wont do it for a few seconds then does it for a few compression cycles then doesnt do it again.
I've replaced the intake manifold gasket twice and the last time replaced the TB gaskets. The first time it seemed like it was fixed but then after driving to boise it was misfiring again. Oh and I replaced plugs less then 2000 miles ago and my wires are about a year old..
BTW one bolt is stripped on the intake manifold its not around the runners but its the one that is on the far left of the motor when looking at it from the front. It doesn't seem like it would leak right there but IDK, i'm stumped.
SORRY THIS IS SO LONG GENTS IM JUST TIRED OF THIS ISSUE AND FIGUERED IF I SHED LIGHT ON everything MY CHANCES OF RESOLVING THIS WOULD BE BETTER..
Any help is much appreciated thanks guys,
