weird hesitation/stutter
slow_tsi
58
Apr 3, 2008
Chillicothe, Ohio
i have a weird problem this just began yesterday after what seemed like fuel cut as the car idles it occasionally stutters as you hit the gas. when you put the car under load its stutters at 2000 rpm for like 6 seconds and takes off. if you decrease throttle a little bit and get back in it its fine. as soon as you get off the gas completely and get back in it it bogs, stutters at any rpm, and then tachs just fine. this leads me to believe its the tps... so i figured ill ask and see if anyone else has run into this its running ridiculously rich as it stutters and only as it stutters black clouds and all
Not if it was completly off
Edit: 100th post in 5 1/2 years woohoo. I try to contribute when I can LOL
Have you or maybe someone else messed around with your afc lately?
Also I noticed you don't have an afpr listed in your profile with that 255 wally?
well you should probably go over all your vacuum/electrical connections, do a boost leak test and go from there.
