Water pump pulley whinning
one_fast_tsi
Sep 24, 2004
johnson City, Tennessee
Bought a 2g awd tsi couple a months back. Car has 135 thousand mikes on it. A/C belt jumped over on me yesterday, partilly destroyed the the belt so I cut it off cause I was at work. Noticed that (what I think) water pump pully was making a whinning noise. Just to be sure i tighented the powersteering and alternator belt. Noise is still there. I was just wondering if this is what the w/pump does before it goes out on these cars. I have never had one go out. Appears that I am not loosing any coolant out the weep hole. Just looking for other directions to check before I tear the t/belt side of the motor apart. thanks for any info.
Are you sure that its not your crank pulley? If it is I would replace it immediately. My waterpump made all sorts of crazy noise when it went out. Does it look like the pully is shaking badly? I could see mine shaking back and forth when mine went out.
Pretty sure that its not the crank pulley. It does look like the pully on the w/pump is just barly moving
