water pump installation...HELP!!
airFS
98
Oct 9, 2006
Harrisburg, Pennsylvania
My water pump is definately broken so I'm going to try to fix it myself, however I cant find any threads or articles on how to reaplace it so I could really use someones help.
installing the waterpump is not too hard, you should put rtv gasket on the waterpump gasket to help it seal well. i think the torque spec is 11 ft lbs. be careful because you will have to feel when the bolt is torqued. if you tighten it too hard the bolt will break. you will have to reset the timing as well.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
