Water pump/Raditor.....PLEASE HELP
97EclipseGS-T
Banned Member
143
5
Dec 16, 2004
Lowell, Massachusetts
Hey hows it going everyone. I recently got a new water pump installed and my AC belt removed and my car started to Idle at like 1200 and somtimes 1500 rpms. My Throttle Position Sensor code turned on when my check engine light was showing a few weeks before, but there wasnt any idle problem. Is is possible that there is air in the lines after the waterpump install? Or is it something else. Please help me, this idle really agrivated the crap out of me.
Yeah, i just put new NGK plugs and wires on. I also Just recently bored out my turbo, bored out my Evo iii housing, and installed a full 3 inch Apexi N1 system, just for variables that might count.
THANX DSMers
If there was air in your lines you would have a major overheating problem. The idle sounds like a TPS problem. Have someone test it, or test it yourself if you have a voltmeter to make sure it is reading correct voltage. Should be .5 at idle and 4.9 at WOT. An inaccurate reading of that will kick the idle of the car up a little bit.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
