pazsion
- 184
- 0
- Aug 9, 2008
richmond,
Virginia
I really want chain timing assembly..but that may be thousands of dollars away..and another motor build entirely..or i haven't found compatable parts from another car yet..i don't exactly have a test engine outside of my daily driver =c
So i'm thinking, how best can i have less wear on my timeing belt, while freeing up horsepower etc..
having an electric pump system would take away from parasitic loss alot.. properly setup and tweaked there is little to no extra draw on the alternater etc...with huge gains at the low-mid-high rpm range, as well as keeping long term maintaince costs down...and increase gas milage..I've run this belt for 6 years? and 40k+ miles..6k miles a year...
delivering food! lots of stop go, get there now...it needs replaceing..i'm at 200,000 miles and going down the checklist of things that could go wrong..
In the end i want a 10-12k rpm motor...so a stressed timing belt would be bad, if a belt / motor even lasts in endurance runs at that speed...the alternater belt keeps coming off or actually breaking -.-
The goodyear alt belt i have now seems good to go tho..
so i'm trying to think of a poor mans way of bypassing the water and oil pumps..only if i can supply a replacement method for it to run..
electric water pump and a oil pump..hoses..easy.stuff...
but how do i make these factory parts idle..without working against the new design? or messing up my engine..or getting overly complex..i'd like for this to be safe and easy for others to do..
i've been able to bypass the a/c pulley with the same belt by getting a bigger idler pulley..
i'm thinking the same thing should work here... remove the pulleys, remove the inner workings.. seal them off.. useing the old parts modified or some fabricated plates..
get a bigger idler pulley...route the belt minus the water pump and oil pump...fit to spec..resize and adjust things as needed..
it'd be nice to have an engine to illustrate this -.-
theres gotta be something to hinder makeing it a easy swap out...
like the oil pump.. how am i gonna tie lines to it...if its pretty much all internal...would the replacement plate be able to be the location of oil lines.. or would the belt etc interfere with the operation...??
my method for the oil pump bypass would be as above^^ remove the oil pumps parts, but retain a seal at that location..and the pump and lines would instead run through an oil cooler and oil filter bypass. at the oil filter location... would this be a good location for the replacement oil pump? why or why not?
repeat with water pump..route a pretty good flow water pump, using the current coolant lines..and mounting the pump securely...what would i be looking for to make the water pump bypass work long term and under stresses?
delivering food! lots of stop go, get there now...it needs replaceing..i'm at 200,000 miles and going down the checklist of things that could go wrong..In the end i want a 10-12k rpm motor...so a stressed timing belt would be bad, if a belt / motor even lasts in endurance runs at that speed...the alternater belt keeps coming off or actually breaking -.-
