Water Pump and Hydraulic Tensioner OEM only?
4gfun
Supporting VIP
2,009
56
Dec 10, 2007
Ask Me, Virginia
What do you all run for the water pump and hydraulic tensioner?
The price of the OEM stuff is rather high but don't want to wreck my engine later.
Any advice would be appreciated.
Thanks
OEM tensioner
and
Gates waterpump
is the general consensus when searching the numerous threads :thumb:
Check out rockauto.com for WP and JNZtuning.com for tensioner. Also get the timing belt pullies. Don't mix the 2 hyd. tensioner bolts with other bolts, they are a special set of bolts.
Thank you.
OEM tensioner
and
Gates waterpump
Thanks...went with the gates to save a few bucks.
Tensioner = OEM ONLY
Waterpump = OEM, or use gates to save a few bucks.
