Water pipe leaking coolant. Suggestions?
SkinnyBAM
203
Oct 22, 2005
Paradise Valley, Arizona
I think I may have put a small whole in my water pipe with a screwdriver a few days back and now its leaking. Anyone know any kind of product that can seal it up? Or any other suggestions so it will hold up until I can get a new one?
You can try some JBweld over the hole, but if you can, just don't drive the car until you can find a new water pipe.
yeah I think JB weld will hold...my buddy used it on his water pipe when he accidently hammered it too much trying to install a big turbo that wouldn't clear the water pipe.
Like the others said JBWeld, but I would only do this as a temp. fix, then instal a new one. Hey HustlerTalon is that the same friend that was jumping on the exhaust manifold?:)
Dustin
brandonzero0 said:
if you need one, i might have one i can toss you, if i do just pay shipping.
That would be sick..let me know if you do. Im going out of town tomorrow but ill be back sunday.
SkinnyBAM said:
Does the water pump need to come off when I put in a new one?
There is a lot of debate over this and I have yet to get a concrete answer to the question of fixing a leaking water pump. I haven't fixed mine yet, so I can't tell you for sure. Mine is leaking at the O-Ring where the pipe meets the water pump.
Some say that the turbo and manifold need to come off to get to the bolts that hold the pipe to the block. Others say that you don't have to remove the turbo and manifold and that you can just unbolt the pipe and slide it away from the thermostat housing.
It only leaks a drop every minute or so and I drive the car about 600 miles/year, so I haven't done anything yet. Hopefully I get off my lazy butt and do something about it when I pull the car out of storage next spring.
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
