Leaking coolant from pipe possibly
jay_wurts
44
Sep 25, 2012
Houston, Texas
The car is the 96 eclipse 420a n/t, I think that its possibly leaking from the pipe on the back of the water pump. I read there was a o-ring that sits in a groove in that pipe so i wanted to start there before taking off the timing belt/ect to see if that will help solve my problem. My question...What all would i have to do to remove the pipe,install a new o-ring and re-install correctly,clamps,tools whatever else. Any help is appreciated!
Basic hand tools is all you need.
A touch of oil or greese is helpfull.
There is a tang or two built on the water pipe that holds it in place.
Remove the hold down bolts, remove the oild O ring, install the new, a whipe of oil or greese on the O ring and the bore.
Reassemble...
Reassemble...
Thanks for your help man,I had some time at work and located those bolts you were talking about. Ill post back and let you know how it works out for me.
