RickClarke23
- 93
- 2
- Apr 5, 2004
Bishop,
Texas
ok....My car is having some problems....it boosts 11 psi and it feels fairly slow like it is trying too hard to move. At first i thought the cause of the problem was my exhaust which was bent after the axle horribly (i have a 3" catless exhaust) and tapered to about 2". So last night i took a grinder and cut the exhaust off after the Rear differential to see if this eliminated the problem. It turns out it helped a little but not alot. I have done Boost leak checks and it held 15psi fine. So then i unplugged the wastegate to see how much boost the car would run. And it would get stuck at 14psi and not go any higher. This also made the car alot slower than before. So i plugged it back in. The car runs fine no smoke. I have not done a compression check. I dont know what could be the problem. Dying turbo?
