Wastegate stuck open or closed? can i fix?
Sicotic
278
May 26, 2009
fairbanks, Alaska
like the title says can i fix it and how do i know if its open or closed.
If you build TONS of boost its closed. If you build next to no boost, its open. Get a new wastegate actuator....or post more info.
heres the vid is this good or bad?
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/MyZXFI1f5kI&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/MyZXFI1f5kI&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
looks like its catching on the inside of the housing,a buddy of mine had this happen and i just ported it out a little and it stopped.
You aint to far from me if i get some free time i might be able to shoot down there sometime,i have a extra wastegate laying around some where i could bring with me.
are u on the OC? Now it doesnt go to 25psi just 20psi, but in 4th it had a little fuel cut, should port the o2 housing? if so can i get a link how to do it.
negative on the ohiocustoms thing....it sounds like it sticking closed check your vaccum lines,look to see if the intake hose is crimping it any.
hell if u find the WG we can meet half way like sunbury or something off of SR 3, what do mean to see if something is catching the WG>
