Wastegate opening @ 5psi
2g spyder eclipse
390
Apr 30, 2013
Milwaukee, Wisconsin
I just installed an o2 dump for my 16g... I never noticed it before when it was recirced. But now as soon as my boost gauge reads 5psi the I can hear the wastegate dumping? It isn't stuck open, and it hits boost fine, just opens at 5psi?
No, if I am cruising in first at 1k rpm I can mash it and have 10psi just below 3k rpms. I guess it ins't a true problem. Just annoying knowing it should slam open at 10psi LOL.
It shouldn't.
If you have a spring that takes 10 pounds of pressure to fully depress then it will start to open earlier.
Joel
