Wastegate melting heat pad
98gsspy
272
Feb 27, 2006
Raleigh, North Carolina
I have the turbonetics t3/t4 manifold with a tial 38mm wastegate on a 4g64, I doubt you 4g63 guys run into the same problem because its designed for your car.
The wastegate is too close and gets too hot so it is burning away the heat pad on the hood.
What are my options
-get thicker heat pad stuff---it will just sit on the wastegate and get burned
Youre right, the 4g64 is just physically taller than the 4g63, hence the contact with the hood.
You could wrap your wastegate with heat wrap unless you want it to look pretty.
You can just remove the sound padding but, that padding also helps protect your paint from blistering if you have something that hot and close to it. Wrapping the waste gate would look like crap, or you could lay down some ceramic high heat paint on the inside or the hood if you take the padding off, this will protect your paint.
Ceramic high heat paint is not a very good insulator, I would not trust your hood's paint on it.
I have that very same setup on my 90' and my hood actually bumps up a little on the drivers side.
I haven't driven it much, so I'm not sure what i'm going to do with that.
But, if you come up with something, post back here, that'd be helpful.
  • For sale 1g 91-94 ignition coil
    1g coil with harness side igniter harness. Digging in a box of remains from a yard six bolt for...
  • Wanted 2g Finish My Project!
    I am in need of some big ticket items in order to finish my project. In my engine bay there is...
    • dhssoccer24
  • For sale AEM Series 2 Total Control Plug And Play Stand Alone ECU For Sale
    I am selling my AEM Series 2 plug and play, fully programable, stand alone ECU. I had bought...
    • LSM
  • For sale 2g 2g passenger side PW switch
    Passengers side PW switch. Good condition. Message 702-741-6987
  • For sale 2GB Factory Owners Manual For Sale
    I am selling the factory owners manual warranty info booklet, and maintenance booklet, all in...
    • LSM
