wastegate hose off
210 dsm
268
24
Dec 6, 2007
san antonio, Texas
ok, i know its a dumb idea because of the chance of overboosting but besides that what are the true negative effects of driving around with your wastegate hose off. just say im'a keep my eye on the boost gage and make shure i dont go over 20psi. dose it actually hurt the turbo or the wastegate itself? or anything for that matter?...
I dont know if your profile up to date, but if you have an E3 16G and no fuel upgrades or control, then your car will not like 20psi. When you take the boost source off the wastegate, it will never open. That means as much boost as possible will build until you either let off or shift. On a stock fuel system you probably could barely get away with 15psi, 20 psi will kill your engine. It also isn't great for the turbo, but you would never notice the wear on the turbo, you'd be too busy rebuilding engines.
