Wanting to buy a dsm
1gfwd16g
30
May 26, 2004
moore, Oklahoma
i am wanting to purchase a 1g tsi. it has the following done to it.
Engine.
Block bored .20 over,new ceramic coated pistons
Big 1G rods,all new bearings and seals throughtout
Balance shafts removed
New timing belt,all new pulleys and tensioner,and new water pump
New radiator
New 160* thermostat
New battery
New brake master cylinder
Prothane motor mounts
NGK plugs
Magnecor Plug wires
Tranny.
New synchros
New exedy clutch
Both new front axles
New clutch slave cylinder
Prothane shifter bushings
Short shifter
Intake/exhaust
Evo III exhaust manifold ported
TRE Ported o2 housing
2.5" mandrel bent exhaust(no cats)stainless steel
Dejon tool 3" intake w/ K&N filter
Dejon tool 3" UICP and 3" TB elbow
GM 3" MAS
Ramcharger MAFT
Turbocharger.
New Big 16G turbo
Stainless braided oil line
RRE 2" turbo outlet pipe
Stock SMIC
Turbo XS boost controller
Suspension.
Eibach prokit springs
New struts and shocks
Front and rear Strut tower bars
Brakes.
Upgraded to 2G GSX dual piston calipers
New front rotors
Wagner pads
Fuel.
Walbro 255 lph hi flow fuel pump
New fuel filter
650cc FIC injectors
Electrical.
New ECU
New knock sensor
Alpine Alarm & keyless entry
Wheels/tires
Stock 1G TSI wheels
yokohama AVS ES100 tires 225/50/zr16
Interior.
New headliner
Dynamat extreme door panels,rear quarter panels,and trunk
Autometer Air/fuel Gauge and boost gauge
its for 4500. is this a good deal
the only bad thing is the 16g and stock smic is this gonna cause me to hve heatsoak and knock alot? and also will leaky valve stem seals cause any major damage besides fouled plugs? what else should i check for besides compression test? thanks guys i really do appreciate it and hopefully ill be joining the exciting dsm world very soon!!
oh and is 16psi safe boost on this car if all the 02 readings and egt temps are good
I would think that is a hell of a deal that i would jump on in a second. U would be running 12's easy with a fmic. Anyhow yes you can run 16psi on the stock IC but i wouldnt recommend it. Heat soak will only happen at the track mainly or if your gettin on and off the thorttle on the freeway. Just make sure you let it cool between runs or put a fmic on it. But i wouldnt be to worried about knock or anything. Looks like he has all the fuel upgrades and suspension and tranny upgrades u would want so if i were you id buy it :)
BTW i didnt see any kind of fuel control? do you know if he has a safc and a logger? or dsmlink? I would suggest not runnin that car past 15 psi until you have a afc and a logger so you can set you fuel settings than you can actually see how much knock you actually have.
well he doesnt he had a pocketlogger but he sold it ummm where can i get a pocketlogger from and what are all the parts i need. do i need a afpr?so i should turn the boost down to 14 or 12? well im kinda new to this so if u can help it would be greatly appreciated
