AL92
- 933
- 4
- Dec 12, 2003
regina,
SK, Canada
I should know the answer to this but ask it anyway.Can you use the rfl turbo xs and will the car run bad.I thought it had washers to allow it to be used direct without a problem or is that for the h34 one so it can be used both ways.I have draw thru maf right now and know with blow thru type it would work fine.
....and it worked fine..no more stalling. I now have a turbosmart megasonic, and it runs great...plus it sounds alot louder.....for example..at 14psi with a HRC 20g, the rfl was freakin loud..like on a scale of 1-10...id say a 8.....now with my GT35r and 14psi, the turbosmart megasonic is deafening...in a good way though.....on a scale 1-10....easily a 15....hope this helps man
