want to put a turbo in my gs please help
Huddleston424
Jun 1, 2009
Huddleston, Rhode Island
i HAVE A ECLIPSE GS AND I WANT TO PUT A 14B TURBO INTO IT WHAT PARTS DO I NEED TO RUN 10 PLUS PSI THANK YOU!!!*DSM*
It would almost be just as easy to find a turbo engine and turbo ecu.
not if you plan on swapping the engines?
420a to 4g63 swap is hard, thats why people just sell the nts and buy turbo editions....
and for the cost of all the turbo stuff, you could sell your nt, and get a nice gsx or something.
just do some research and make the decision:)
but if you wanted to turbo the 420a you would need new exhaust manifold, turbo, oil feed and return lines, o2 housing, new exhaust probably. im not exactly sure, but it most likely wont be a walk in the park....
I hope that was an attempt at sarcasm...
I've never personally seen a 420a turbo mani with a mitsu flange on it. BUT you can buy the t3 turbo exhaust manifold and the t3 to mitsu adapter to make it work.
As far as getting the supporting mods, search till your eyes bleed, then search more. It will be good for you.
The t3/mitsu adapter plate to a t3 manifold is probably the best bet.:thumb:
As far as the rest of the turbo process for a 420a, there is plenty of searchable info on that.
