want to check out my datalog?
AKbag
42
13
Oct 4, 2015
Anchorage, Alaska
did a wot pull anyone care to look at it tell me what you think? hit knock and have some boost creep. pretty sure that i have way to much boost for pump gas. (90 oct). any way im slacking on this whole profile thing but the car has. e316g, 650 injectors, 255, 3inch exhaust, front mount,gm maf. that's about it.
Your injector duty is around and above 90% at WOT when you knocked (you should also dial in your TPS because it doesn't read 100% with your foot to the floor) and your wideband reads around 12-14afr and its shooting for 9.5 so it seems like you're running out of fuel considering the fact you have stock fuel pressure, 650ccs and the afr was good before you knocked. I'd recommend getting a fuel pressure reg. and turning up the base pressure.
