VRS exhaust
David15151
905
9
Aug 31, 2004
Augusta, Georgia
I looked around the forums but didnt see much about it. Anyone able to testify about it? I have a picture of the o2 eliminator.. but im a bit discouaged in its design.. hope this pic works. What are your thoughts about this product? Its either VRS or the R&R.
The angle of the where the air comes off the turbo disturbs me.. at that angle won't it give backpressure and just cause more boost creep? Or would the exhaust gas going through the main tube create sort of a vacuum to help it exit....
My o2 housing looks worst than that. It is not as "pronounced" in the exit area. Mine looks as if it is too flat.
BUT..... I have ran it like that for over 1 year and I got NO boost creep on an internally gated Tdo6h 20G. None what so ever. The car put down 311whp at 21psi with 89oct and NO creep. That o2 housing you have there in the pic looks pretty good. Most all that are internal gates are like that. The only thing you will find about the system is the tri-bolt flange is not used by others (only HAHN that I have seen) and that it puts your DP close to the oilfilter.
The rest of the system is pretty damn nice!
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
