Voltage Regulator question
Elvenhome21
625
5
Oct 21, 2006
Sheboygan, Wisconsin
I am wondering how you can boost the voltage output from the alternator. On the GM delphi alternators you put a resistor on one of the leads to the VR. I have never taken a mitz alternator apart or know how these VR are diffferent from the GM.
I am looking for around 17-18 volts, I have a racing battery that is 16 volts and it does have a 12 volt post off the battery for the ecu stuff. I just don't want to spend $300 on the 16 volt alternator and charger. I know there is a way I just can't find it.
I played with one earlier and found it wont go much more than 15 volts .
The feed back to the alt is on pin 1 on the alt plug the one close to the engine putting some resistance there will bring up the voltage some but it must have a built feed back to prevent high voltage output in case of wire damadge .It put out the most whith this wire off (15-16 ). So it would not be enough to realy help on charging the 16 volt batt .
  • For sale 2g 2GB Eclipse Reverse Lights ( with bulb sockets )
    2GB Eclipse Reverse Lights ( with bulb sockets ) $35 + shipping & paypal feesYou must be...
  • For sale 2g Tan Sun Visor Set ( with home button & hardware )
    2G Tan Sun Visor Set $50 + shipping & paypal fees* home button * hardware includedYou must...
  • For sale 2g 2G Black Ashtray/Cup Holder
    2G Black Ashtray/Cup Holder $35 + shipping & paypal fees* both sides open and close as they...
  • For sale 2g 2G OEM Radio Brackets
    2G OEM Radio Brackets $35 + shipping & paypal feesYou must be registered to see element.
  • For sale 420A 420a Miscellaneous Parts
    Hey Guys I have a 420a car that just came in, if you’re looking for any miscellaneous engine bay...
