fuel lab air fuel pressure regulator question
Dose anybody know if you need to use Teflon tape on brass fitting end on fpr? The fitting that return fuel back to the tank?
The brass fitting on your fpr return line does not need any tape or an o-ring. Do not over tighten this fitting though or it can leak. Those type of fittings need to be just a little over snug.
:thumb:
As for those blue anodized fittings they need to have 1 o-ring between them and the fpr unit.
That is also an Aeromotive AFPR.
:thumb:
Ok thank you so much for your help! i got the o-ring on the an fittings too.
:hellyeah:
Yes it is, i borrow a pic from a member.
Mine is Fuel lab AFPR and i don't have any pics of it. I don't have a camera to snap a pic right now but the fitting are exactly the same tho. I got the Fuel Lab AFPR from extreme psi a couple of days ago.
I cant see the picture due to my connection. But if its NPT then yes put teflon tape on it. If its AN, use a rubber oring to seal it.
Ok ill put taflon tape on NPT's too. Thanks bro.
Oh, one more thing! Fuel Lab fuel gauge is not liquid fill, why is that? I don't know if they all come like that
