Video of my 16g Laser at the Track.
beansblacktsi
285
53
Apr 2, 2007
Lincoln, Nebraska
I have been meaning to post this for awhile but this is my 12.23 at 113.75. I Could of probably got it down to a 12 flat but they closed the track early but Im still happy with my times. This was all done on stock 140,000 mile motor with factory head studs and head gasket, stock head, stock trans with a rps 6puck clutch, 1000cc injectors and walbro 255. It is tuned with ecm link and e-85 on 21lbs of boost. Let me know what you think.
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/63bz37C3iqU&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/63bz37C3iqU&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
What do you have your launch limiter set to and what is your tire set up? 170s are pretty impressive!
I could only do 190s on street tires and a slipping clutch the last time I was there...
I believe my 2-step was set to 5500 and Im running kumho 225/50/16s or something like that. Ill have to check but they are just all seasons. I think the car has 1.6s in it but it was a chilly day and I was spinning first but who knows.
Nice pass! Sounds great! With a better 1-2 shift I'm sure you could be closer to 12.0. As much as the squat looks killer, it hampers the 1-2 shift, and your absorbing some power with all that movement.
Thanks everybody and yes I fully know that a good suspension setup would help the car but its just one of my daily's and a fun reliable snow machine. The reason I didnt crank the boost was because of the stock head studs, the heads never been off at all. And I'm really happy with the 340 horse it put down for such a low boost level and that was only at 15 degrees timing!! So its just a fun realible car and don't worry I have an Awd colt that will be my 1/4, 1/8 mile car which should be good for some low tens, high 9s!!!!
