vibration under acceleration after warming up GST
u2civic1
Mar 1, 2008
costa mesa, California
I'm getting alot of vibration under acceleration after 5 to 10 mins of driving, its drive smooth in the morning but after about 5 to 10 mins of driving and braking it starts to vibrate and shake when under any and all acceleration. I've changed inner tie rod, alignment, no play when lifted off the ground. I'm gonna try and replace the rotors to see if that helps. Any other suggestions?
if your getting vibration under breaking then of course start with the brakes, stuck caliper or warped rotors. if your getting vibration under accelerating theres a number of things it could be, rebalance the front tires, check the motor mounts, or it could even be your balance shaft belt being loose...
more onfo on the problem would help
I replace the rotor didn't help, mounts look good, it weird that it only happens after 10 to 20 mins of driving. There isn't any knock or timing getting pulled so I doubt its the engine.
I've got new motor mounts, new rotors, axles cv boots look good, timing is good, changed inner tie rod, alignment, no play when lifted off the ground, no balance shaft. Does anyone have any suggestion?
