vibration in the wheel
justinhill98gst
190
Sep 1, 2007
White bEAR laKE, Minnesota
Hey guys, I just got done taking the transmission out about a month ago to replace the throw out bearing and before i did that the car had no vibration in the wheel, this vibration is about at 70-80 mph i brought my car to get the tire balanced and they where all fine. I also replaced the driver side lower control arm. and then once and wail when i revise with the wheel crank to the right i hear a quick snap sound,this does not happen every time though, the car drives straight with no pull. I went over everything and i do not see anything wrong. what could i check that would cause this vibration? do i need to get the car relined after replacing the lower control arm?
IDK but you could check your CV joint. That could be the slap or maybe tie rod end but you said you checked everything. The only other time I had that problem was my wheel wasn't bolted up correctly.
Could be ICE build up LOL.... But I don't think thats your problem.
No dents on your rims? Mine have been balanced and still get a little vibration.
Is this coming from up front on the car? Did you check drive shaft? What about brake rotor? Wheel bearing? Axel nut and or brake caliper bracket bolts?
