Vibrating at highway speed
ViChives
Nov 11, 2004
Milwaukee, Wisconsin
I just fixed the oil leak in my turbo feed line and now I'm having vibrating problems. The car idles smooth and the vacuum gauge is between 22-20 and boosts fine. My clutch does slip if I try to take off above 3000RPM. I'm not sure it the clutch is slipping on the highway but it accelerates strong if I give it gas. At 60MPH my car is around 3200RPM.
Symptoms
1. Sometimes when I let off the throttle, the car vibrates badly. It has a different sound like a hum and the car feels like it is slowing down between gear changes.
2. When I'm on the highway with speeds above 60mph I can feel the vibration and it's more noticeable when the right side of the car goes over bumps. If I give it gas the vibration goes away, but returns right after slow down or start to cruise.
What I've checked
1. Made sure the Transfer Case has fluids.
2. Checked right CV axle and it looks ok.
3. Put car in neutral on highway and the vibration stops.
4. If I rev the engine with no load it does not vibrate.
5. All my spark plugs look normal.
  • Wanted 95 eprom
    Looking for 95 eorom
    • GhostTypeP0300
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
